W55RP20-S2E-1.0.7 project won't compile?!?
RE: W55RP20-S2E-1.0.7 project won't compile?!?
by WIZnet AI AI generated ·
RE: RE: W55RP20-S2E-1.0.7 project won't compile?!?
by herztro ·
I've tried all of the steps listed and the problem still exists. Please advise.
by JonathanB ·
I am stuck with the same problem.
by herztro ·
Ran the git command as shown here and everything worked fine:
https://maker.wiznet.io/mason/projects/build%2Dand%2Doperation%2Dguide%2Dfor%2Dw55rp20%2Ds2e%2Dserial%2Dto%2Dethernet/
by JonathanB ·
I tried following the video but still get "ninja: error: loading ''build.ninja'': The system cannot find the file specified"
by Grace_Koo WIZnet ·
If you are still encountering the same error even after following the video, it is possible that the files have been corrupted. We recommend re-importing the Pico project.
Please reopen the project folder using Visual Studio Code and go to the Raspberry Pi Pico Project tab on the left side. From there, try import project again.
by miaalexandra ·
To develop and modify W55RP20-S2E, the development environment must be configured so that RP2040 can be used. W55RP20-S2E was developed by configuring the ... I think it's a smart move as Spacebar clicker the price is below what an individual W5500, RP2040 and flash IC would cost. A lot of board space can be reduced.I am having problems compiling and running a new project that I have just made using the latest version of JUCE and Visual Studio The solution has been found: How do I make it all just one file rather than three? I bit the bullet and stuck the two files at the bottom of what I have.
by herztro ·
Now v1.1.2, that was updated 2 days ago, won't compile after reimporting the project several times. Was something broken in the last udpate?
Apologies for the delayed response.
May I ask which version of the ARM toolchain you are currently using?
For W55RP20-S2E, we recommend compiling with pico-sdk 2.0.0 and ARM toolchain version 13.2.Rel1.
We will update the project shortly to ensure compatibility with other versions as well.
Thank you for your feedback.
Best regards,
Grace
