Wizfi360 wifi disconnects/reconnects
- MQTT
RE: Wizfi360 wifi disconnects/reconnects
by WIZnet AI AI generated ·
RE: RE: Wizfi360 wifi disconnects/reconnects
by youaretrippin ·
In the Wizfi360 firmware for the AT+MQTTSET command, what is the value set for the cleanSession flag? Is there a way to change this during configuration?
by Patriciabin ·
A Station disconnects to the WizFi360 ... • During the UART-WiFi passthrough transmission, if the TCP connection breaks, WizFi360 will keep. Open Port in Serial Program and input AT. If WizFi360 return OK, AT spacebar clicker command can be used. Page 6. WizFi360 Quick Start Guide.— WizFi360 is a complete and self-contained WiFi network solution that can run independently or as a slave host MCU. The module can be booted ... This document will guide through a series of steps from configuring development environment to running Arduino library and examples using the WIZnet's Wi-Fi ...
