W5500-EVB-PICO check after reset
RE: W5500-EVB-PICO check after reset
You must be doing something on the W5500 after PHY reset you did not show here in the post. For example trying to open socket in the loop and that’s why activity LED is flashing. Look at the Wireshark output to see effect of your code on the traffic.
RE: RE: W5500-EVB-PICO check after reset
by dimaios ·
Thanks for your reply.
To be more precise I show you all the code starting from the main() function:
If I put a breakpoint after the function set_PHY_configuration() I have to wait a lot for the yellow led to stop blinking.
There are no instructions other than those in the code snippet.
I cannot really understand this behaviour.
Kind regards
