W5500 send is not working
RE: W5500 send is not working
How you can’t send it? I bet
sendreturns status, but you do not read it. You can look at what is going on the network by capturing data exchange at the remote node using e.g. Wireshark.Where exactly?
RE: RE: W5500 send is not working
by Sametzedmir ·
It works when I put a delay inside the for loop.
I am having such a problem because I use the send command in the interrupt. I don’t face any problems when I use it in the main loop.
I think the reason is a problem with interrupts. However, when data arrives, it interrupts but exits without sending.
What would be the reason?
Is callback running in separate thread, or in the same thread as
forloop? In other words, may there be a W5500 access conflict?RE: W5500 send is not working
by Sametzedmir ·
All code as above.
Please help me.
How can I help - you must provide info I asked for. Status code for
send, and if callback runs in threaded mode.What exactly the command for delay?
by Sametzedmir ·
I am struggling with the problem to solve it. And finally I discovered this. If I constantly query getSn_RX_RSR(sn) as polling, I have problems with send(). I observed an improvement when I increased the duration of the getSn_Rx_RSR(sn) query.
What can i do in this situation.
My best regards,
IMHO you anyway seem to be doing something wrongly, and you’ll sometimes get the faults.
If execution is threaded, then there may be access concurrency to the chip. Even if you do not use threading and using interrupts, if interrupt occurs during executing chip access you’ll get faulty result.
by Sametzedmir ·
Actually the situation is this. I constantly perform the send operation on the interrupt when there is a getSn_RX_RSR query. It works fine when I put a wait or remove the getSn_RX_RSR query. I’m using the W5500 chip’s own libraries.
I’m trying hard to solve this problem I’m encountering.
I’m open to your ideas.
When accessing chip with single command or in specific sequence in main loop you must disable interrupts.
by Bekdemir ·
Bu soruna ait bir çözüm www.bekdemir.com.tr sitesinde mevcuttur.
Fazlası ile yardımcı oldu, özellikle stud çivisi ile alakalı olarak
