W5500 UDP stop sending after a while
RE: W5500 UDP stop sending after a while
Not clear from your description if send and receive are fully asynchronous.
If yes, this may have problems - send and receive use same registers (e.g. status register, command register) and you must NOT run these handlers concurrently. Queue the tasks.
RE: RE: W5500 UDP stop sending after a while
by besthere ·
Thank you for explanation and suggestion!
I have to do in full asynchronous application scenario. Now I used one socket receiving from pc and added another socket sending to pc. The test seems good with running about an hour without question.
But I still don’t quite understand why receiving kept stable while sending always stops when I used these handlers concurrently.
