Problem sending large data buffer with W5500 and ioLibrary
RE: Problem sending large data buffer with W5500 and ioLibrary
What
strlen(payload)returns exactly?RE: RE: Problem sending large data buffer with W5500 and ioLibrary
by seands ·
That question got me thinking a bit more about memory. I moved the definition of
payloadinto the global scope and it now works. I am not sure why it didn’t work before though, because shouldn’tsend()be able to see the variables in the scope ofsend_dataif I pass a pointer to it?This bug seems really bizarre - why did it work for a 32 byte buffer and not much higher?
by kenearl ·
Hi Seands,
You might want to check if wizchip_init returns 0?
