WIZ750SR Noise on analog GPIOS
RE: WIZ750SR Noise on analog GPIOS
by Alan WIZnet ·
Hello. How many ADC channels did you use together? Did you only use one?
RE: RE: WIZ750SR Noise on analog GPIOS
by Ironic ·
Hello @Alan
I tried several configurations with similar results.
I also noticed strange things. GPIO A seems to have a weak pull up to 3.3V enabled by default in analogue mode. It pulls the analogue value at its pins to a higher value.
Also, GPIO D in digital output mode alternates between GND and 3.3V at about 1-second intervals. This happens in several modules.
Regards
by Alan WIZnet ·
You mean ADC used only one channel…? It was often a problem with more than one ADC channel. However, I didn’t see any issues with ADC 1 Channel. Even when we tested it, it didn’t matter when we activated one ADC.I will test it with the module and share the results with you. Thank you.
by Ironic ·
Dear Alan
The graph I showed was taken on GPIO B.
For my application, I would like to use 3 analogue inputs and one Digital Output. The issue is that it seems that GPIO A has a pull up to 3.3V in analogue mode (and lots of noise) and GPIO D is alternating between GND and 3.3V at about 1-second intervals so it seems it is being used by some other function in code… GPIO B and C are just noisy.
Regards
by Alan WIZnet ·
There seems to be a problem.
Please contact us by e-mail below.
Alan@wiznet.io
