WIZ750SR Boards not able to re reset or connected to
- WIZ750SR
RE: WIZ750SR Boards not able to re reset or connected to
by Grace_Koo WIZnet ·
Thank you for the detailed description.
To look into this further, could you please let us know the following?
1. Firmware version
You mentioned the configuration tool shows version 1.4.2 for the board you set up manually. Could you confirm this is the firmware version? If you know the firmware version of the previous batch, please let us know as well.
2. Configuration tool version
Which exact version of the configuration tool did you use to apply the config file? If you know which version was used to create the config file originally, that would also be helpful.
Best regards,
by Senteq101 ·
Thanks for your reply.
Version 1.5.4 was used previously of the configuration tool and have used this for a long time. I do not have any of the older boards to find the firmware from unfortunaley.
I have tried the latest version of the configuration program 1.5.8 but this still does not allow me access to the boards.
How can i reset the boards and enter manually as i have 6 boards i can use and need to get soem programmed for an install?
Andy
Hi Andy,
Thank you for the information. We understand you need to get the 6 boards back so you can set them up manually for the install.
Please try recovering one board in boot mode first:
1. Power off the board.
2. Connect the APP_BOOT pin to GND. On the WIZ750SR module, this is the APP_BOOT pin (PC_14) on the J4 header, right next to a GND pin.
3. Power on the board.
4. Search in the configuration tool. The board should appear with the status "BOOT".
5. Select the board and click "Factory Reset".
6. (Optional) While the board is in boot mode, you can also update the application firmware to 1.4.5 with the "Upload" button, using WIZ750SRv145.bin from:
https://github.com/Wiznet/WIZ750SR/releases/tag/v1.4.5
The firmware update guide is here:
https://docs.wiznet.io/Product/Modules/Serial-to-Ethernet-Module/WIZ750SR/download#wiz750sr-firmware-update-guide
7. Power off, remove the APP_BOOT-GND connection and power on again.
8. Search for the board and enter the IP and port settings manually.
For now, please enter the settings manually rather than applying the config file. Could you also send us the config file? We would like to check which setting causes the boards to stop responding after a power cycle.
If the board does not appear in boot mode, please let us know and we will send you the steps to recover it over serial with the ISP tool.
Best regards,
