지속적인 Socket Close -> reconnect 시 Interrupt 과발생 문제
RE: 지속적인 Socket Close -> reconnect 시 Interrupt 과발생 문제
You must give more technical information. Interrupts do not happen out of nothing, something triggers them. What interrupts? When they occur? What socket is doing when it occurs? What network is doing when it occurs. Explain he whole case, otherwise you most probably won’t get useful advice other than you incorrectly program something not following the workflow.
