MagJack selection wrong?
RE: MagJack selection wrong?
Wiring seems to be in accordance to this. But IMHO would be more correct using 009 type of MagJack.
by ibuddy ·
Thanks. I agree, that the 009 parts are more similar-looking to the used jacks on the Wiznet boards, however, I do not understand the big difference.
Unfortunately, I would like to use PoE. Do you know a working Magjack connector for the 5500 with PoE? Do you know, from the electrically/digital point of view, what makes the difference in the coil positions inside the magjack?
Tomorrow I am going to try to connect a magjack from Wiznet board.
by ibuddy ·
I was able to verify, that the w5500 is operating when connecting the ethernet jack from a wiznet board. I will make a new board and would like to ask you, if these two jacks would work with POE:
WE 7499211125
Abracon ARJP11A
Thanks in advance.
RE: RE: MagJack selection wrong?
I do not see the reason why not, but anyway advise you to perform prototyping before making the product.
by ibuddy ·
Thanks, I’ll test it.
by ibuddy ·
Just want to let all know, that my first MagJack selection was wrong.
I can verify, that the Wuerth connector is operating, at least I can get an IP from a DHCP server.
Thanks for your help!
