[W5500 SPI Issue] No Response On MISO
RE: [W5500 SPI Issue] No Response On MISO
by cq td ·
I try to set BaudRate 50M/8M or others, It’s no working. Problem is still exists
RE: RE: [W5500 SPI Issue] No Response On MISO
You can see that MISO responds to the command with 0x01, 0x02, and 0x03, thus SPI communication works properly. Simply the data being accessed (what SPI command is used?) is all zeros.
by cq td ·
all of register return 0x00,
Why do you think they must return non-zero values? Read VERSIONR, it is guaranteed not to be 0 whatever configuration chip has.
by stefanoallegri ·
i am having the same problem, i mounted a breadboard board and connected the SPI signals between an ESP32-S3 module and the ETH WIZ CLICK demo board and this works fine, i then implemented the same scheme on my circuit and the MISO signal does not never goes to “1” I see it go to “0” when the CS is set to “0”, but I never see it go to “1”
this is the schematic of ET_WIZ_CLICK: https://download.mikroe.com/documents/add-on-boards/click/eth-wiz/ETH_Wiz_Click_v101_Schematic.PDF
and this is my schematic:
with oscilloscope:
but do not see any replay from chip, MISO (pin 34) go low when nCS go low and goes back high when the nCS goes back high
Can anyone give me pointers on what I could go look at?
If you look at this picture you can see MISO being low level before any transmission, therefore you seeing 0 after you activate CS must be normal. Then, as you send bits to the chip together with the clock, chip replies with 1-2-3-data. the fact that you do not see these replies may mean chip does not get anything from your MCU. Thus you first must look into SPI mode you use, if clock within spec and if all the wires connected properly to the chip.
by stefanoallegri ·
exactly, I checked with an oscilloscope right on the pins of the chip that the CS, the clock and also the MOSI arrive, I also checked that the 25MHz crystal is oscillating.
but I don’t see any activity on the MISO
by stefanoallegri ·
I have two boards (one ETH WIZ CLICK demo) that mount this marking code :
W5500
DU3432
2214
and the board where it doesn’t work mounts this other marking code :
W5500
DU6776
2219
i’ve also tray to reduced at 15MHz the SPI clock (the previous test i’ve made with 25MHz) but obtain the same result, any MISO activity
