WIZ550S2E TCP not working on corporate network. loses first 16 bytes of data.
RE: WIZ550S2E TCP not working on corporate network. loses first 16 bytes of data.
by jcomfort ·
A follow on to this earlier post. Command mode UDP messages have the same problem. OK in data mode, but when sending on a corporate network we again lose the first 16 or 17 bytes in UDP using AT+NSEND
any suggestions?
thanks
John
Hi John,
Could you share the ‘*.pacp’ file that captures the problem?
RE: RE: WIZ550S2E TCP not working on corporate network. loses first 16 bytes of data.
by jcomfort ·
Hi Austin,
I have attached the filtered file (tcp.port==4437) to keep it small!
Hope this is of use
Best regards
John
John Comfort
JCA Systems Ltd
(Attachment EC4Plus_LAN_BATH6 filtered.pcapng is missing)
by jcomfort ·
Hi Austin,
Hope this is of use
Best regards
John
John Comfort
JCA Systems Ltd
EC4Plus_LAN_BATH6 filtered.zip (15.5 KB)
