Is my W5500 damaged by the wrong ExRes1 resistor?
RE: Is my W5500 damaged by the wrong ExRes1 resistor?
by ghuang ·
On the layout side, the instruction said “void power and ground planes under discrete magnetic components”, but I am using the integrated transformer (J1B121ZCCD) , so I did not follow that rule. But I don’t think that be the reason causing the whole chip not functioning.
by ghuang ·
At least this crystal does not seems good according the calculation
https://wizwiki.net/wiki/lib/exe/fetch.php?media=products:w5100s:w5100s_crystal_selection_guide_v100e.pdf
I am not sure if the W5500 still have the same gain margin with the W5100 or not.
But I am ordering few other cyrstals with smaller CL and will try it next week.
Question:
Even if the loop does not oscillating, which means I don’t get 25MHz, should I measure some voltage, maybe DC on the pin 30/31?
Thanks,
