send Ip fragmentation for UDP
RE: send Ip fragmentation for UDP
by louis ·
In the case of UDP, if the data size of the incoming packet exceeds 1,472byte, it will be recognized as wrong data on our chip. It is recommended to split it into 1024 bytes per packet and send data to the chip.
by kirant400 ·
I want to send data from W5300. Not incoming. How to send using IP fragmentation.
