WIZ5500 Ethernet Packets not being sent correctly via MACRAW
RE: WIZ5500 Ethernet Packets not being sent correctly via MACRAW
by louis ·
Hello
If transmission is performed normally, you will receive an for the transmission packet from the other party.
If you have received the normally, Sn_TX_FSR will automatically increase.
If Sn_TX_FSR does not increase, it is because the other party does not send the ACK.
Monitor your with the wireshark program.
RE: RE: WIZ5500 Ethernet Packets not being sent correctly via MACRAW
by Shreel ·
Hello louis, I am sending ethernet packets from one W5500 to another W5500 which means that I cannot use wireshark to monitor what is being sent. I only have a limited visibility to what I am sending and where to.
I have figured out how to send a packet but now I am stuck trying to figure out how the W5500 receives packets. Is there anyway you could help me with that?
