Cannot connect W5500 as TCP Client
RE: Cannot connect W5500 as TCP Client
The first think to do is review our Loopback example.
You have to write values to network related registers before OPEN operation.
These registers are optional, so you don’t need to set it up, and it has values by default.
And in my opinion, it would be good to check if SPI is working normally.
W5500-EVB : GitHub - Wiznet/Loopback_FRDM-KL25Z_Eclipse: Create a repository of WIZnet Freescale Example.
IoLibrary : GitHub - Wiznet/ioLibrary_Driver: ioLibrary_Driver can be used for the application design of WIZnet TCP/IP chips as W5500, W5300, W5200, W5100 W5100S.
RE: RE: Cannot connect W5500 as TCP Client
by Ricardo Tonet ·
Hi. Thanks for the response.
I found the problem thanks to your suggestion. SHAR and SUBR values were wrong. After correcting them everything worked well.
Ricardo
