W5500 SPI not response
RE: W5500 SPI not response
by agent47 ·
In the meantime I have replaced the L1 with a ferrite with 120 ohms at 100 MHz (BLM21PG121SN1D).
But that didn’t help.
In my circuit diagram, the yellow LED is also connected the wrong way round, but that shouldn’t be a problem for the time being.
When I plug in a network cable, the green LED flashes irregularly. So, at least on the network connection side, everything seems to fit.
At the VBG pin (18) I can also measure the 1.2V which should also be present according to the data sheet.
I still have the problem that I don’t get any answers from the W5500 chip on the SPI bus.
Does nobody have an idea why that could be?
RE: RE: W5500 SPI not response
by scott WIZnet ·
Dear @agent47
There doesn’t seem to be a big problem with your circuit.
You have both SPI and Ethernet not working?
Basically, you should check if 25MHz is working.
For SPI, first check the connection with your MCU.
For Ethernet, check out our Design Guide.
https://wizwiki.net/wiki/doku.php/design_guide:hardware:start
by agent47 ·
The network part works. The connection to the mcu is ok (all traces are connected).
by jackyjoy123 ·
thanks my issue has been fixed.
