Sending data Problem in TCP mode
RE: Sending data Problem in TCP mode
For security, the TCP Server device you are using may not respond to the packets sent by the W5500. Turn off all security programs such as firewalls. When data transmission is stopped, we need to find out in what circumstances it is stopped. Can you capture packets through wireshark?
The normal operating temperature of W5500 is around 45 degrees.
