WIZ550io + IOShield A + Arduino M0 USB issue
IO Modules
IO Modules
RE: WIZ550io + IOShield A + Arduino M0 USB issue
by wf2020 ·
Looked at the schematic, the fix is to cut off the IOREF pin on the shield. The IOREF pin, labeled +5V, is between the pin labeled J3 and the pin N_RESET. The Shield will receive 5V from the other pins labeled +5V. The 5V is down regulated to 3.3V so the Arm chip on the M0 is working as expected.
The USB is now active and I have successfully loaded up the Ethernet2 WebServer example code.
I suggest that if another version of this shield is produced that the IOREF pin is left unconnected.
Thanks
W
RE: RE: WIZ550io + IOShield A + Arduino M0 USB issue
I’m glad you solved it well.
Thank you for your suggestion!
