Wiznet W5100 with STNRG388A
RE: Wiznet W5100 with STNRG388A
I recommend reading and writing RCR and RTR registers. The initial values of the registers are 0x07d0 and 0x08 respectively, and are registers that can be written.
RE: RE: Wiznet W5100 with STNRG388A
by sohaib86 ·
Thanks for the response.
I have been doing some random tests with Arduino and STNRG interfacing Ethernet Shield.
Below are some of my observation, if anyone can get me some hint.
Waiting for some positive response.
by sohaib86 ·
This figure is SIPR3 register read operation, is it right?
Yon must be set up yourself the Source IP address .
Wiznet Chips don’ t save the network information.
Network information mean subnet mask, ip address, gateway …
also, If CSn is keep low state, the delay doesn’t matter.
by sohaib86 ·
Thanks for the reply, i have changed the SPI instructions sequence. Now the four bytes are going at once with CS low for four bytes of time.
Actually the problem was SC18IS602B’s MOSI pin, it was not driving the Wiznet MOSI pin due to low current capability. Now i have added 1K Pull-up resistor on MOSI line and i can see the response from Wiznet 5100 and got the IP using DHCP.
Thanks for the responses.
Hi~~
I’m glad you solved it well. I’ll definitely remember about Pull-up.
Thanks~
