Wiznet w5100s evb arduino skeych
- Arduino
- Arduino IDE
RE: Wiznet w5100s evb arduino skeych
by WIZnet AI AI generated ·
RE: RE: Wiznet w5100s evb arduino skeych
by akilraje ·
Tried the code but still it says Ethernet shield not found and further for your kind information im usin Wiznet pico EVB which is an integrated of pi pico and wiznet WS5100S.
by matthew WIZnet ·
What product are you using?
It would be easier to troubleshoot if you could tell us which W5100S board you are using on which board.
For your information, if you want to use the WIZnet Ethernet HAT (W5100S) on the Raspberry Pi Pico, you need to set the CS Pin to 17.
