Using BLE to TCP wiznet example and library does not set up IP, GW, Subnet mask correctly on W5100
RE: Using BLE to TCP wiznet example and library does not set up IP, GW, Subnet mask correctly on W5100
by ToasTer86 ·
I was able to fix this myself, by reading the complete data sheet of the wiz5100 I found out I needed to change the SPI mode.
My bad sorry
