WIZ750sr - TTL Standalone
RE: WIZ750sr - TTL Standalone
Do you have see a serial message of WIZ750SR?
First connect the PC and module directly, then please check the ip with serial and send ping.
by Daniel Katzav ·
Hi
Thank you for the quick response !
I have a good ping from the PC to the 750sr.
I am able to send packets from the PC to the 750sr - and that transfers into the Serial module I am converting from - and it actually reaches the other end, however, I have no ping in between one PC to another.
RE: RE: WIZ750sr - TTL Standalone
Could you please draw your connection diagram?
And are all products(Two PC, one WIZ750sr) on the same network?
by Daniel Katzav ·
Yes - here is the diagram:
My goal is to send ping from PC1 to PC2.
For now - my only success is that I can ping from PC1 to the following 750sr module (the one that is connected with an Ethernet cable to the PC1)
You can see in the diagram that I connect each 750sr to the others following the RS-232 connections - and since I configured them as a TCP Mixed - I am trying to get network traffic both ways, also to the fact that they are dual duplex.
All the components on the network are the same exactly - I even use the same brand and length of the Ethernet cables.
Let me know if you need to know anything else,
Daniel
It’s difficult to send ping as your diagram.
WIZ750SR is serial to ethernet module only for TCP or UDP.
And it is only to deliver data.
It is not possible to send requests and receive responses via serial.
