W5500 How to put data in Socket TX buffer
RE: W5500 How to put data in Socket TX buffer
Are you success at reading and writing other registers than the tx buffer?
I don’t know what to do for you. If you show your code I can confirm it.
Do you not use iolibrary?
In the case of tcp, data is sent through send() in socket.c.
In addition, I recommend to refer w5500.com .
There are w5500 code for stm32 board, but it is a Chinese site.
You should refer to it using the translator.
The following is an W5500 TCP Server Example on Keil Project.
http://w5500.com/code//W5500EVB/zip/TCPS.zip
