W5500 hangs router
RE: W5500 hangs router
by jameskim ·
Can you share your old code and new one with us?
With both codes, we may be able to investigate what the root cause was.
And do you have any file which you captured packets in when the router crash happened?
If not, I’d like to ask you to capture packets with the old code using wireshark.exe.
RE: RE: W5500 hangs router
by 114r5 ·
I am not allowed to share the code and neither have wireshark captures from the moment of the crash. I can make captures of the current behavior if you want.
Don’t you know any general reason that may cause the router to act like this? Maybe IP or port conflict, or too many open ports?
by acpie360 ·
What are those two TCP sockets, server or client? I am not sure what “static port” means in your statement. Are you using the WIZnet ioLibrary?
by 114r5 ·
TCP sockets both act as client, pointing simultaneously to two different servers.
As static port, I mean that one arbitrary source port value is assigned and is always the same for each socket (0xCA00+socketNumber).
No WIZnet ioLibrary. I am creating my own functions. If you ask for a certain bit of code, I might be able to share it.
by jameskim ·
In fact, we have never got any reports like this from customers.
So, we can’t guess what made this symptom.
The packets when the router gets crashed are helpful for us to investigate.
I am sure router logs will tell you the reason for its reboot/hanging, or will at least give you an idea what was happening before problem occurs.
