W5500 works on some routers but not others
RE: W5500 works on some routers but not others
I’d suggest start with the roots - looking at the network traffic using Wireshark to identify what happens when communication freezes. Then, when you have this info, you try to understand why it happens - from both sides - considering the appropriate RFC. When you found out where process is broken, you raise the bug or try to fix the way you (or we all) can modifying software under your control.
