W5500 responding to SPI, but hangs on socket creation
RE: W5500 responding to SPI, but hangs on socket creation
I will tell hardware engineer about your question.
He will response about it.
@Scott
You seems have made a number of mistakes in your board.
RE: RE: W5500 responding to SPI, but hangs on socket creation
by ntldr ·
Thanks for the reply.
Very likely. It’s my first slightly more complex design compared to those that I could easily plug together on a breadboard. So any help is greatly appreciated.
Where exactly is the mistake? It’s connected to the transmission center tap of the RJ45 Magjack and ground, the same as in the reference schematic (C8 in that one).
Right. Not sure where I got 51R from.
Good catch. Looks like I used the external schematic there for some reason.
I’ve been using an Epson FA-20H 25.0000MF20X-K3 crystal with a 10pF load capacitance. I followed the formula found in the ST Oscillator design guide (AN2867) (CL = (C1*C2) / (C1+C2) + CStray), which yields me a C1/C2 value of 10pF for an assumed 5pF stray PCB capacitance. This is one thing that I’m especially unsure about, as I have very little experience with external oscillators.
All resistors I used are 1%.
Yes, via an inductor (L1 on the PCB). I double checked an measured that 3V3A is present on the W5500.
It’s hooked up to the main MCU (STM32F401RET), which pulls it down for 500ms pre-initialization and then pulls it back up to force a clean reset. I’m waiting for another 500ms before continuing with the initialization (via wizchip_init) to ensure the chip is ready (the W5500 datasheet specifies 150ms for that, but I’d rather be safe).
I’ve swapped out the Resistors with some 49.9R 1% now and this gets me a bit further. Now I end up getting stuck a few lines further in the socket function [1].
[1] https://github.com/Wiznet/ioLibrary_Driver/blob/master/Ethernet/socket.c#L236
Sorry my mistake. You did it correctly.
Very good.
Try performing software reset after this hardware reset. Set bit 7 of MR, and wait until it clears to 0, and then proceed to the chip configuration.
by scott WIZnet ·
Dear ntldr
I’ve reviewed your PCB photos.
Did you connect the GND to trace?
GND is weak, it is difficult to operate the analog side.
You should be connected to GND is plane.
Scott
by zzwwss ·
Hi ntldr
May I ask if your problem has been resolved? I have encountered some similar problems and would like to refer to your solution
