W5500 SET UP DIRECTLY THROUGH ETHERNET
RE: W5500 SET UP DIRECTLY THROUGH ETHERNET
No, and it should not, as this will be serious security breach.
RE: RE: W5500 SET UP DIRECTLY THROUGH ETHERNET
by centurymetering ·
Sir,
Thanks for your immediate reply.
But in the WIZNET108SR we are able to set these parameters directly through the ethernet.
We thought, we should be able to do the same thing in our board without having to resort to another port of the supporting micro controller which after receiving the data through one of its UART ports, programs the on board W5500.
Regards
VTC
Century Metering Systems & Controls Pvt Ltd
by lawrence WIZnet ·
Hi, centurymetering
there are two ways to set network information by ethernet communication.
first one is you set board’ network information at the first time. Then you can connect the board via ethernet and change the information (Actually, WIZ108SR using this way)
second, by mac communication(like ARP), you can communicate the board without default network information.
All wiznet products support macraw communication. But this concept is from wiznet. So, it is hard to find examples out there and you have to make your own application for it.
I recommend you to set default ip network, and then change it through udp or tcp communication.
thank you
Sir,
Thanks for the information.
We will try to implement your suggestion.
Regards
VTC
