Altera FPGA Board with W5300 - TCP or UDP
RE: Altera FPGA Board with W5300 - TCP or UDP
Hi~
Please refer as below.
This project is using the MCU and W5300.
https://www.wiznet.io/wp-content/uploads/wiznethome/Chip/W5300/Software/W5300_driver.zip
thanks
RE: RE: Altera FPGA Board with W5300 - TCP or UDP
by Saras015 ·
Thanks for your response.
In your attachement, i am able to see only Codes. So Any example design using WIZNET 5300 For Alter Quartus will help me most.
How to interlink Tristate conduit bridge/Generic Controller with WIZNET 5300.
Currently, i am reading the counter data in NIOS using FIFO (SOPC). Now i need to read the data in PC through WIZNET 5300. Please anyone guide me
Hi~ I think you want to use PC and W5300 through network , Is it right?
If is right, you should be select the network protocol(UDP or TCP).
Please refer to previous code about how to use of this protocol(loopback.c)
thanks,
