Wiz750sr manually CTS/RTS
RE: Wiz750sr manually CTS/RTS
If you are using WIZVSP and the hardware flow control function, you need to control the CTS of the virtual COM port that sends/receives network data.
This setting can be checked in the ‘Signal lines’ tab. (based on the latest version of WIZVSP: v2.0.2)
