2 serial to 1 ethernet implementation
RE: 2 serial to 1 ethernet implementation
Hi, bwynn
2-port serial to Ethernet products are not yet available as ICs. I recommend you WIZ752SR-120 products hardware pin compatible with WIZ120SR module.
RE: RE: 2 serial to 1 ethernet implementation
by Tomasz ·
I was buy WIZ752SR-120 yesterday.
Unfortunately the module it always returns to the factory settings after the power supply is disconnected.
Please help me,
Thomas
Can you tell me more about your ‘getting started’ process?
Note that when you change the settings of serial to Ethernet module through the configuration tool, you must press the [Setting] button at the top of the config-tool program to apply the changed settings to the product.
by Tomasz ·
When I was saved the settings for WIZ750SR-120.
The settings will be applied and the module will not automatically reboot.
However if the power supply is disconnected or I click the button reset, module always to the returns factory settings.
The module was tested for many tool version (0.5.0; 0.5.1; 0.5.2; 0.5.3; 0.5.4) and behaves the same for everythings version.
How many version firmware to WIZ752R-120?
Please help me,
Thomas
