is it working?
RE: is it working?
Hi, hsieber,
The easiest way to verify the working of Serial to Ethernet is to prepare two terminal programs - TCP server and a serial terminal such as Hercules program - to connect to each module and then transfer data in both directions.
Below ‘getting started guide’ link will help you.
WIZ750SR is a 1-port Serial to Ethernet product almost similar to WIZ107SR.
https://wizwiki.net/wiki/doku.php?id=products:wiz750sr:gettingstarted:start#connect_your_wiz750sr
