W5500 DHCP Problem
RE: W5500 DHCP Problem
Yes, you have set 18.0.255.255 as your gateway in GAR field, or it serves as destination IP address in DR field. The correct broadcast destination address in the local segment is 255.255.255.255. I would also suggest you perform dump of all common and related socket’s registers to see how W5500 is configured.
RE: RE: W5500 DHCP Problem
by jburrell7 ·
Eugeny,
Thanks for the assistance. I found the problem and it was in my code. My SPI routines expected data on 32 bit boundaries which worked OK for most of the drivers, but not so well for the DHCP drivers. After modifying them to allow for data on 8 bit boundaries, all is working as required.
Thanks, again.
Jeff.
