Registers of FCTRLR, FACCR, FCTRLR for programming of flash memory
RE: Registers of FCTRLR, FACCR, FCTRLR for programming of flash memory
by jim ·
Dear Ilya
Maybe you saw the following topic.
We didn’t open documents of flash memory registers because you cannot handle that in firmware level.
You have to use IAP to control flash memory in W7500x chip.
RE: RE: Registers of FCTRLR, FACCR, FCTRLR for programming of flash memory
by Ilya ·
I use Assembly code, so I have to know the numbers os bits in the register FACCR, FACTRLR and FSTATR. You may understand, that if I use Assembly, I cannot use the IAP libraries. And in the manual there is no description of IAP function. How can I use IAP function for write to flash-memory from program (!), but not simply from external source (for example SPI).
by Ilya ·
Hello! We managed to write flash memory through Assembly code with help of the IAP functions. Thanks for your advice.
Best regards!
by barcaluti ·
And what about the flash protection registers? Can this be managed with IAP? How can I setup flash protection via FLOCK0 and FLOCK1?
Regards,
