Target not created using Keil uVision
RE: Target not created using Keil uVision
by Jimmy Andrianto ·
HI,
i try to find more information about FCARM and i found this link: https://www.keil.com/pack/doc/mw/Network/html/group__nw__sw__util__fcarm.html and i remember i add favicon.ico file to the project files. Sorry its my false
. When favicon i deleted i can compile again. Its SOLVE my problem, but i still want to know how to add the favicon. The picture already places at img folder (the same places with webpage.h here the link of example files at github: https://github.com/Wiznet/W7500/tree/master/W7500x_Library_Examples) and i has add using html code at webpage.h but still not shown.
If somebody have experience to add the favicon, could you inform here?
by Alex Fatiuk ·
It is an old post, but I had the same problem and couldn’t find solution so I thought I post it here.
After adding more files to my project - it just stopped compiling with the above message. Here is my fix: when you right-click on the added file and select Options for File, check the file type: it should be C source for C-files. It was “Image file” instead in my case, after changing it to C Source it compiles again.
RE: RE: Target not created using Keil uVision
by FV Labpan ·
Tanks, thanks, it works
