Some informations about W5500
RE: Some informations about W5500
by Kei ·
Do you intend to control the WIZ550io (this is not include MCU) with the board you said?
Then it is possible.
To communicate directly with the PC, you can use the protocol that is provided in the PC.
Typically, it uses TCP or UDP.
Please refer to the code in the link below as a reference for your code implementation.
RE: RE: Some informations about W5500
by Vermu ·
Thanks for the tip !
I’ll use a FPGA to configure the chip, I hope I’ll still find some useful informations about the chip in the code
Thanks again,
V.
