Strange output
RE: Strange output
by Kei ·
Does the carriage return and line feed print well?
If so, is it followed by !!!?
And let me know the serial settings of the module and the settings of the terminal program you are using.
RE: RE: Strange output
by awescales ·
Hi Kei
Thank you for getting back to me, I am not on site at the moment but from memory, the serial settings were 19200, 8, N, 1, software control flow.
Static IP, mixed mode, no data packing, no serial configuration.
The output is as I typed it with just the 3 ! and no cr or lf
RE: Strange output
by Kei ·
What does “software control flow” mean?
When you see that CR LF is not output and !!! is output, it seems that there are serial setting and other problems.
