Pin connection of WIZ100 board
RE: Pin connection of WIZ100 board
by scott WIZnet ·
Hello StevenMedusa
I answer your question.
You need to connect VCC and GND to only one of JP1 or JP2.
If you want to use Ethernet, you need to connect the 1 pin of JP2 to the CT of RJ45.
Ask more questions.
RE: RE: Pin connection of WIZ100 board
by StevenMedusa ·
Hello Scott,
Thank you for your response!
I am not sure if I understand this. Using the developers board I can indeed verify that this is correct. But according to the PIN assignment of the WIZ100SR manual, pin 1 is the PWFBOUT. What does this mean? What is send over this line?
And I have a second question: Would it be possible to use the S2E chip without an RJ45 socket? We would like to use the chip in following ideal case:
[WIZ100SR chips] → flying leads connected to an ethernet cable → Ethernet plug that inserts into a PC
So basically that an ethernet cable is cut and directly connected to this board. I know that there is some electronics present in the RJ45 sockets, but would it be possible to skip this or use some other smaller components for this?
by scott WIZnet ·
Hello StevenMedusa.
PWFBOUT is a 3.3V power supply.
There is a transformer circuit inside the RJ45 connector. 3.3V should be connected there.
It is recommended to use RJ45 connector. But you can do whatever you want.
WIZ100SR - Transformer Circuit - Ethernet Cable - PC
You need to do this.
I’ll send you a circuit and RJ45 datasheet for your reference.
See the transformer circuit in the RJ45 data sheet.
WIZ100SR.zip (199.7 KB)
