Error in starting the server in pic18f4520
RE: Error in starting the server in pic18f4520
by Kei ·
Is this function modified by you?
It is different from ioDriver’s function form.
I want you to re-check the code with the following information.
W5500 TCP Function Application Guide
And,
Please refer to other topic below.
by Shade ·
Looking at your initialization I noticed you assert the Hardware Reset line, apply 1 ms delay, then de-assert the Reset line and apply another 1 ms delay.
I would suggest to toggle the Reset line without using any delays, then start polling the PHY Configuration Register (Common Block, Offset 0x2E) for RST Bit (0x08) cleared. This happens in less than 1 ms.
From this point you can apply Software Reset and start Register initialization.
Below is some pseudo code reflecting this approach.
When your initialization is complete, your device should be responding to pinging its IP Address.
Good Luck!
