Error 400 on GET or POST method with lightHTTPD server
RE: Error 400 on GET or POST method with lightHTTPD server
Francis, make your Android server logging everything which comes from the client. I assume there’s basic log file which would show some details about what is going on, but you would need to log whole header and contents. Error 400 is bad request which means that your Android server does not understand something in the request. One bad character transmitted may cause such behavior of one type of servers while others may just discard bad characters.
by SkywalkerF34 ·
Hi Eugenie,
Thank a lot for your explanation and time to answer.
I know the code 400, but cannot find the solution with this server
I move to orangePI board with lubuntu and Appache server ans this works marvelously well
I still focus to install on ANDROID system but seem APPACHE server are not available on ANDROID
Problem stil pending, if anyone has found the solution ???
