W5500 server is 255.255.255.255 error
RE: W5500 server is 255.255.255.255 error
I think the connection between the Arduino and the W5500 module is wrong. Check other register values using the code below.
Serial.println (Ethernet.subnetMask ());
Serial.println (Ethernet.gatewayIP ());
RE: RE: W5500 server is 255.255.255.255 error
by Indramal ·
Now the connection is ok. But Server not showing in computer. I directly connect through Ethernet cable.
When I go to page it is show
Is it a cable problem? Cross or nor?
Serial Output give
My home network is also 192.168.1.__ range.
by Indramal ·
Now it is connected thank you very much
