Configure UART0 (PB_2,PB_3) on mbed
RE: Configure UART0 (PB_2,PB_3) on mbed
by lawrence WIZnet ·
Hello, joaopaulob
I think you do not need to use HAL_PAD_AFConfig()
Only you need to declare Serial Class : Serial serial(PB_2, PB_3);
But if even you success the compile, it does not work.
You must change D0(U0_RX), D1(U0_TX) alternative function to GPIO.
Because the D0, D1 order is stronger then PB_2, PB_3 ( I think… )
Thank you,
lawrence
like this…
Digital Output(D0);
Digital Output(D1);
Change the D0, D1 function and declare PB_2, PB_3 as UART0.
RE: RE: Configure UART0 (PB_2,PB_3) on mbed
by joaopaulob ·
Lawrence,
I did:
DigitalOut dummy1(PA_13); //D1
DigitalOut dummy2(PA_14); //D0
When I call the function ( Serial serial(PB_2, PB_3) ) I got the error “pinmap not found for peripheral”.
It looks like the mbed do not allow to use these pins for UART0.
Any idea?
Best regards,
hello, joaopaulob
This is what I captured on my web compiler.
Could check your compiler with below lists?
→ refer the right side and up in that capture.
lawrence
by joaopaulob ·
Hi Lawrence,
The program compile successfully, but it freezes on running.
Try to run the following code:
Best regards
hello, joaopaulob
Thank you so much!
You are Right!..
It is my fault… I never thought about mbed library.
WIZnet missed add PB_2 and PB_3 in Serial pin map.
Refer below capture.
So… Now you have two solutions.
lawrence
by joaopaulob ·
Found a way to “hack” the mbed:
