Do not init network
RE: Do not init network
How did you know it? Why do you think “network attrubites” are not initialized?
Please explain your issue.
by linuxbergi ·
I understood not read registers. But why?
Working procedures for 5500:
uint8_t wizchip_read()
{ uint8_t rb;
while (!(SPI1 → SR & SPI_SR_TXE)); //check buffer
SPI1 → DR = 0xFF ; // transfer
while (!(SPI1->SR & SPI_SR_RXNE)); // wait input
rb = SPI1 → DR ;
return rb;
void wizchip_write(uint8_t wb)
{ uint8_t rb;
while (!(SPI1 → SR & SPI_SR_TXE)); //wait buffer
SPI1 → DR = wb ; // byte to line
rb = SPI1 → DR ;
For 5100 it does not work. Can faulty “hardware”?
What is the actual circuit diagram of your module?
by linuxbergi ·
Files attached
2.pdf (108 KB)
1.pdf (52.3 KB)
Circuit seems to be ok. I propose using scope or logical analyzer to see what is going on with SPI bus and there’re no issues with it (for example, 16 bit communication instead of 8-bit communication).
