Problem reading Flash memory (W7500p)
RE: Problem reading Flash memory (W7500p)
by Kei ·
Hi, danielski.
To give you a detailed answer, I need some more information, such as the board name and version you are using.
Anyway, I tested your code.
Looking at mbed.h, I thought that it was written in the mbed environment, and I proceeded with the mbed compiler.
Is that right?
Here, I have an answer.
In your code, there is no initialization for Serial, how did you check the contents of printf?
Anyway, I attach the code I modified.
I did not include W7500.h and added Serial initialization.
In my case, it worked just as you intended.
(disable DO_IAP(IAP_ERAS_DAT0,0,0,0) and DO_IAP(IAP_PROG,DAT0_START_ADDR,save_buff,SECT_SIZE) and try to read the data that I wrote previously)
Best regard,
Kei
