AX1 as Server to test Telnet client Example, Arduino DUE
RE: AX1 as Server to test Telnet client Example, Arduino DUE
Hi.
DUE + ioshieldA serial monitor output is normal operate?
First, please checking IP setting from wiz550io(ioshieldA)
If you don’t know, use arduino example web server(basic) code.
File → example → ethernet → webserver
If normal operate, Please checking telnet client code.
AX1 is basically Loopback TEST tool.
