Problem during WIZ107SR FirmwareUpgrade
RE: Problem during WIZ107SR FirmwareUpgrade
Hi, Christian.
Please check the WIZ107SR H/W revision.
The firmware version after v3.04 is for WIZ107SR H/W revision 1.3 / 1.4 only.
The latest firmware version of WIZ107SR revision 1.1 is v2.20.
Please try to check again.
Regards,
Eric.
by Haspel ·
the problem after WIZ107SR Firmware Upgrade is no longer visible, now we have 5modules 5 malfunction modules. Is there a way to describe this new?
rev 1.1
Hi, Hespel.
what version firmware did you use?
as I mentioned above, the WIZ107SR rev.1.1 module should be used to firmware version 2.20.
by Haspel ·
we use the version WIZ107SR _FW_V220 from 12/07/2013 this has be installed without problems
