LINKLED Always On
RE: LINKLED Always On
hi.
LINK LED is always on. It is true (Your RJ-45 Yellow LED)
And active LED is blink (Your RJ-45 Green LED)
And GND is very dangerous.
Shield is CHGND. Checking the Reference Circuit (below URL)
wizwiki.net/wiki/doku.php?id=pro … fschematic
And Do it ping test.
Ping test is join the command mode (cmd) and “ping xxx.xxx.xxx.xxx(IP)” ex)ping 192.168.0.11
by mav ·
Thank you for your help. Also I would like to thank Wiznet support guy, Lucid. He helped me to figure out the problem.
The main problem is that 4pin should be connected the AVCC. After connecting pin 4 to AVCC the chip came to life!
