AT+WA Time to connect to AP
RE: AT+WA Time to connect to AP
by wizdaniel ·
Hi
would you like to tell AT command list you used to me.
Thanks
by bannoura ·
Is there any problem in the firmware of the WIZFI. Is there any documentation about the timing of the chip.
Im using SPI to communicate with the chip. So I reset the CHIP and then I wait around 1 second then sends an AT Command to initialize the chip. The next commands that I used AT+WD, ATC1, AT+ NDHCP=1, AT+WWPA=.
Then I connect AT+ WA=TEST
The Problem is that the the timing of powering the chip until the connection is more than 15 seconds and I need to know if it is possible to reduce it less than 10. I believe the problem is in the Firmware of the WIZFI.
Any suggestions would be helpful.
