Connecting to the Web server
RE: Connecting to the Web server
by wizdaniel ·
Hi lhakim.
You have to modify {xx} command to HEXA code.
For example {1B} command means a hexa code of the ESC key function.
{0x0d}{0x0a} means carriage return and line feeds as known as ENTER key function.(\r\n)
So you can get the response from cloud server after typing ESC, carriage return, line feeds instead of {xx}.
You have written incorrect GET method.(GET api.thingspeak.com/update?key=F … field1=200 HTTP1.1\r\n)
If you want to connect and send queries to thingspeak.com, you can prefer the api note of thingspeak.com like the link below.
Thingspeak.com needs the string of information(POST ~~, api_key ~~, message ~~)
AND it have to be just sent as below rules.
client.print(“POST /update HTTP/1.1\n”);
client.print(“Host: api.thingspeak.com\n”);
client.print(“Connection: close\n”);
client.print(“X-THINGSPEAKAPIKEY: “+writeAPIKey+”\n”);
client.print(“Content-Type: application/x-www-form-urlencoded\n”);
client.print(“Content-Length: “);
client.print(tsData.length());
client.print(”\n\n”);
That source was included in the link below
[url]http://community.thingspeak.com/arduino/ThingSpeakClient.pde[/url]
by lhakim ·
Hai wizdniel,
Thanks for the reply
I already manage to update the data to thinkspeak.
What I do is use serial.write in arduino to send hexa code to serial.Below is my test code
