How to use driver?
RE: How to use driver?
by Coccoliso ·
ATMega128A it is not among the official board but is an Arduino? Maybe it Arduino Amber?
What I seem to have realized is that you do not even familiar with the development system of the card … right?
If so you should first practice with the development IDE and then become interested in devices that can be connected.
If is an Arduino board you can start from here [url]http://www.arduino.cc/[/url] and download the latest IDE to begin.
by dinartal ·
I use Atmel Studio IDE and connect w5100 to SPI. I don’t want to use Arduino. I have w5100 library but don’t understand how to write code. I need some examples of TCP/IP server initialisation.
by Coccoliso ·
I also do not use arduino but I converted these sources for other MPUs.
See app note here [url]http://wiznethome.cafe24.com/wp-content/uploads/wiznethome/Chip/W5100/Application%20Note/W5100_Application_Note.zip[/url] for DHCP and DNS examples calls routines that interest you instead In what you have already downloaded there are routines ( in modules W5100.c and socket.c) for W5100 registers and listen function.
For the server mode setting sequence instead look here [url]TCP Example] is for the W5500 but is practically the same.
